Removing the crank pulley bolt alternative
Sorry no pics!
This was never an easy job, this is just a kind of ghetto way I found that worked. I did actually HAVE the tool but this turned out to be what got it off in the end (that's what she said)
NOTE: This process I know works on MANUAL cars and can be performed on Auto (In park), thanks grifty.
Aim: Remove that damn pulley bolt without using a pulley holder tool or air tools and not damage anything in the process.
Required: Another human being with one strong leg, big ar$e breaker bar, extension pole if you need more leverage, socket extensions, 19mm socket, floor jack and 2x stands, WD40, patience.
Steps:
I haven't seen this method posted anywhere so I thought I'd share my experience.
Step 1:
Jack the car up, place jack stand under the car at the correct jack stand point and keep the jack as backup support just in case. 2 points of failure is always better than one!
Step 2:
Remove all the plastic shroud so you can get to the bolt on the crank pulley. Remove spark plug leads and plugs so we are not fighting compression. We don't want to damage anything remember.
Step 3:
Make up your breaker bar with extensions so you can get some leverage clear of the car and attach 19mm socket to the end and stick that on the pulley bolt. Use the second jack stand as your support at breaker bar end, this helps eliminate any wasted twisting effort. WD40 is helpful here too.
Step 4:
This is where the magic happens, get your buddy in the car and have him place the car in first gear and STAND on the brake hard. You can't have the engine running so you wont have any hydraulic braking assistance here. Now stand on that breaker bar and get the bastard off. By locking the rotation of the axles with the brakes, which is connected to the gearbox which is connected to the crank, you should be able to get the bolt off. The risk of damage is minimized and best of all, no holder tool required!
Other comments:
Hardest part is actually keeping the brakes from not spinning as you don't have assistance here, you just need to be He-man about it.
Tips: I was doing this just after i had washed the car, probably the wrong way around you might think but the rust built up on the brake disk actually helped the pad bind to the disk better. And hey the car's clean too.
Good luck!
