Dimple Magnetic Drain Plugs
		We are proud Australian distributors for Dimple Magnetic Drain Plugs.
http://i1276.photobucket.com/albums/...ps088b5309.jpg
Your gearbox and diff don't have filtration systems like your engine, so the tiny metal particles just go round and round, ruining your gears bit by bit until you change the oil out, which is at least a year for most people.
Dimple plugs keep your oil spotlessly clean because they are the strongest magnets on the market, period. They pull out and hold ferrous particles from your oil so that your gears run clean. The effectiveness of Dimple plugs does not break down at higher temperatures either, unlike many others on the market - they're actually designed to put up with heat. They are made in the USA and are lifetime guaranteed. You can fit them to both the fill and drain plugs on your gearbox or diff, as well as your engine oil drain plug. All Honda models in stock. They ship with a crush washer of the same dimension as factory standard.
Watch our video if you don't believe us on how good they are:
http://www.youtube.com/watch?v=WStdwSKBnGY
We are putting together a Honda-specific video, too.
Price:
$44 for the first one, $40 for each after – all models.
