Wondering how to adjust my buddyclub n+ coilovers on 01 dc2r..
Do i have to remove lca's or anything?? Kinda hard to reach the bottom ring with c spanner
what adjustment? preload? hight? damper? eather way its 2 bolts to drop the rear lower control arm so it would have taken less time then starting this thread
Adjusting damper:
- Look for the upper mount poking through the chassis near the strut bar (front) in the boot behind the left and right plastic trims (rear)
- Adjust the damper by turning the damper adjustment nob in the center
- Turning clockwise stiffens
- Turning anti-clockwise softens
- Count the clicks from the softest or the stiffest to give you an idea of where your damper setting is at
Adjusting height:
- Jack up car
- Secure with jack stands
- Remove wheel
- Loosen the lower locking perch (the bottom ring on the shock)
- Turn the whole coilover system by using the c-spanner on the lower spring perch (The rings under spring)
- Tighten lower locking perch on the shock once done
- Make measurements between lower spring perch and lower locking perch to give you an idea of the height
There should be a smaller c-spanner and a larger one. You may have to turn your wheel to full lock to get better access on the lower half.
