Can an Integra flywheel fit the S2000 AP1?
Hi,
I have been doing a lot of research and havent found any definitive answers. The closest I can find is someone saying the flywheel is the same, and pilot bearing might be a different diameter.
I have an 8lb lightweight flywheel from a DC2 Integra, also have the pressure plate and friction disc, but the pads on the friction disc are worn down with nothing left. If the flywheel will fit, id like to put that in my S2000.
Im also wondering if the pressure plate will fit, as this pressure plate is rated to 2600lbs of force while i have read the oem pressure plate delivers 1600lbs of force. If so I can buy a new friction disc, or have this one repaired (the rest of the friction disc is perfect, springs, etc, just no material left), and fit the Integra flywheel, pressure plate and new friction disc into my s2000.
Does anyone know anything on this subject?
