Been trying to get error codes for em1 civic. Bridged the PINS on SCS connector and turned on ignition switch to position 2. MIL just comes on and off like it usually does. No flashes. Any ideas?
did you bridge the 2 pin connector that is blue in colour ?
Yeah shoved a paper clip in there. nothing happened
if it goes into diagnostic mode the MIL on the cluster should come on and stay on.
where did you find the SCS, what colour is it
http://www.ozhonda.com/forum/showthr...ECU-for-j00-!&
i think may be useful
Found the blue plug on front passenger side. Under the glovebox on the right. Do you think their could be a fault with ECU? ECU is ob2a.
EM1 is OBDIIb
I would deliberately force a fault code into the ECU, perhaps disconnect the MAP sensor while the engine is idling. The MIL should come on, then when you shot the SCS the MIL should pump out code 3 or code 5
you can always reset the ECU after
if you do not get the MIL come on and codes in the ECU the ECU has problems.
ECU is off ek9. Ill give it a go. thanks
ok, EK9 ECU is also OBDIIb
Just wanted to add there is no MIL when I start the car. Does that mean no faults detected?
Anyway started it without the MAP sensor and MIL just stayed on. No flashes. No detection? Is my issue something else non-detectable?
are you bridging this connector
http://b16a2.kicks-ass.net/diy/pgmfi...ekejem-001.jpg
hope your not bridging the 3 pin connector
