Aim: Lift your EK9 wing up a bit with out using the brackets which look like shit
Required: spacers/nuts/gromets
Steps:
-Remove your stock EK wing by removing the plastic under the boot then the 4 screws
(NO PIC)
-Take off the base plate from the ek9 wing and add spacers/nuts/gromets/whatever you want to slide on to the rear stud on both side. the more it is the more lifted the wing
http://i42.tinypic.com/70hm49.jpg
-Here I have just added enough to be inline with the stock stud. Put the base plate back on and bolt it down using the other stud
http://i42.tinypic.com/2znqq00.jpg
-Final result
That little tilt makes a big difference in real life
http://i40.tinypic.com/2eyurs1.jpg
From the back still looks stock with out that weird bracket look
http://i42.tinypic.com/2zz0zl4.jpg
Couldn't get the best photos and angle as theres another car in the way to get a side on shot
http://i43.tinypic.com/1ooq5u.jpg
http://i39.tinypic.com/c6ipy.jpg
http://i42.tinypic.com/33epfk1.jpg
For OEM or spoon wing refer to this DIY I have made.
http://www.ozhonda.com/forum/showthr...ock-EK-LIfters
