1 Attachment(s)
Rear Trailing Arm Bush freeplay - thoughts on this install
Hi all,
I picked up a dc2 few weeks ago, have been working through fixing up a few things. While checking the rear end I inspected the RTA bushes.
A previous owner had installed some polyurathane RTA bushes - I thought this was a good thing until closer inspection.
Passenger side is upside down (the "top" marking is facing downwards), but are they in back to front as well, there is at least 2mm free play b/w the washer and the bush as shown in this pic. Anyone have similar poly bushes and can comment on freeplay/orientation?
Both driver and passenger have the same amount of clearance to the washer and there are some clunking sounds which I believe are caused by this.
Never mind the white in the pic, I sprayed them with lithium grease before I saw the freeplay.
