MY12 CU2 Euro - Wheel Alignment Specs
Hi all.. wondering if anyone can post the factory wheel alignment specifications for a MY12 CU2 Euro (base model).
My car's done 25,000 kms and the rear tyres are scalloping. I went to the dealer to get this fixed, but the dealer uses someone else to do the wheel alignment and I suspect from the print-out that the specs of the standard Accord were used. Even if they are same on both cars, the final measurements seem wrong to me:
https://dl.dropboxusercontent.com/u/...0Alignment.jpg
Camber is : -1.71 (initial) & -1.72 (final)
EDIT: This was take 2 on the alignment. I had taken it to a bridgestone tyre center earlier.. they used the same specs.. fixed the front but left the rear measurements as is !
Thanks in advance..
