hi guys, been searching on the forum, I still couldn't figuring out which spec I should use for the JAZZ GD VTI
Just for normal driving , no high rev at all, I would change oil every 5000km, so I should go for 5W40 or 10W40 or 10W30?
How many kms are on the engine atm?
Unsure how long you've had the car but is it burning the current oil?
I would run Penrite HPR5
if youre changing every 5k kms, then pretty much any oil within oem viscosity range will do lol, its only a jazz
5w30,10w30, 5w40, 10w40
the car is almost 80000 on clock ...
Yallah i use genuine FEO honda oil. does the job. I have also used the Penrite and i have found that the FEO gets dirty much quicker than the penrite. that being said, if you change your oil regularly, its not much of a problemo.
Ive used FEO 10-30, FEO Ultra 5w30 and Castrol Edge 5w30 on the Jazz
Between the three ive found the Castrol Edge to be the best, also good price when on sale
10W/40 is not too heavy for the Jazz engine.
Hasn't oil choice been mentioned somewhere before :o
