Oil Tempetures.
Hey so im running a b16a2 with bsr injectors tuned ecu and a cai + extractors and 2.5in exhaust ( pretty sure maybe 2in )
I was wondering what kind of oil temptures other people get with their b16 / b18 when ur into it ? Daily driving the gauge says around the 90 degree mark . Then usually when im into it , its around the 120 mark. but tonight i went for a quick run where i live held the car in vtec for around a minute straight and the gauge was reading 150 degrees . Is this normal ? also the oil pressure dropped which makes sense tho because the hotter the oil gets the easier it flows .
Where are you measuring the temps?
From sensors next to oil filter I usually run at about 180F (80-85c) and when pushing it or under sustained load gets up to about 240F (115c).
This is with turbo and sensor is before the oil cooler which has a thermostat. Before i had the oil cooler it used to run hotter more of the time but even then the max I ever saw was 250F
Really shouldn't go too much over about 120 for any length of time...
