TracTuff K series products *JDMyard*
http://farm8.staticflickr.com/7354/9...6566c521_b.jpg
http://www.jdmyard.com/image/cache/d...e-500x500.jpeg
Jun "Reproduction" Bolt-in K Series Oil Pan Baffle $215 incl gst Pick Up
The Bolt-in K Series Oil Pan Baffle is a unique product that easily installs between the OEM Windage Tray and Oil Pan Floor. The baffle extends deep into the oil pan, dividing the sump into three sections, with the largest section surronding the oil pumps pickup. The dividers section off the sump so as to keep oil from moving aggressively from one side of the pan to the other during hard corning. The open top design still allows adequate return oil flow to the pan. The design is simple and effective... it keeps the pickup submerged longer during aggressive driving.
Features:
Easy Bolt-in Design
Fits all engines using K20A/A2/Z1 oil pump and pan.
Cost Effective Oil Control Solution
Manufactured in the USA
US grade 6061-T6 aluminum
High-Strength Blind Rivets
Improved Mounting Hardware
Fits both K20A and K24A alloy or steel oil pan with PRB/PRC Type R oil pump
Installation and details :
http://www.jdmyard.com/index.php?rou...product_id=746
http://www.jdmyard.com/image/cache/d...4-500x500.jpeg
TracTuff Timing Chain Cover Baffle $45 incl GST Pick Up
Simple solution for limiting the amount of oil that is allowed to move up the timing chain cover side of the k-series engine during spirted driving.
Initially it was designed to be installed in a machined timing chain cover but as we played with the finished product we realized it was so thin... machining was not necessary. The product installs simply by being sandwiched between the timing chain cover and oil pan. Simply add Hondabond to both sides of the baffle as well as a little extra where the height changes
http://www.jdmyard.com/index.php?rou...product_id=744
http://www.jdmyard.com/image/cache/d...V-500x500.jpeg
TracTuff K20A IACV Rotator $75 incl GST Pick Up
The TracTuff K Series IACV (Idle Air Control Valve) Rotator spins the IACV 180* so the plug faces the engine rather than the radiator; especially helpful when your plug is hitting the core of your radiator! It also does a great job of hiding those unsightly wires.
Kit includes CNC machined adapter, Genuine Honda O-ring, 1/8" NPT plug, and two socket head mounting screws.
