Has anyone experienced this before for some reason my gear 5 has this stiff feeling moving into it, it just doesn't feel right its as if it's no lubricated and when you move it into gear it's really slow and stiff any ideas??
Haven't heard of this happening to fifth before. Usually occurs to people's 2nd gear and changing transmission fluid usually sorts the issue out... failing that - synchro.
I'd change the fluid and go from there.
How many KM's are you at?
What year is the car? :-s
Just look through your posts, for a 2002 if its never had the transmission fluid changed I'd definitely do that first, considering its now been in there for 11 years :-p.
DIY *EP3 Specific* How To Tranny Fluid Change MTF small Pics! - http://honda-tech.com/showthread.php?t=2155139
Also whilst searching I'd maybe even consider this for future service intervals.
how much MTF oil is needed to fill up? about 2-3 quarts?
1.7l
check your engine bay, make sure shifter movement on transmission is not obstructed.
had something similar before... but it was happening on random gears..
sometime it would get stuck in reverse...
got my transmission fluid re-filled and it helped a little but was still getting random stiff changing into gear... then one day!
BAM!!! my master and sale cylinder was gone!! got it fixed and since then
changing gears hasnt never been so smoothed since then! :)
