need help does anyone know what gives a more accurate reading for a/f ratio between kmanager and the wideband sensor?
the ratio on the wideband shows leaner then on kmanager on the laptop...for example if it shows around 14.6 on kmanager, on the wideband it'll show around 16 and higher.
so basically i need to know which is more accurate or do i have a technical issue somewhere and they should be both reading the same?
