Long shot..
But whos had experience in Kinugawa gear or Forge wastegates?
Long shot..
Kinugawa turbo's are basically Mitsubishi turbos...
So you can get a new actuator locally to suit.
http://www.turbosmart.com.au/product/iwg-universal
http://gcg.com.au/
You can change the springs in the turbosmart unit also to suit yourself
ahh good to know, but im more interested in particular the actuators as a replacement.... as i need a 5psi and most oem actuators are around 8 - 10 psi
pricing for kinugawa is $100 vs forge $200!
Wouldn't it be easier to buy a electronic boost controller or if you're using hondata engine management I'm relatively sure there's a boost control feature?
Running a greddy EBC already, the issue im having is the turbo wastegate isnt holding boost, with/without an EBC, an my tuner already said its the wastegate thats at fault.. so in need of an upgrade... and these 2 are the only replacements as they can give me the correct spring psi as its a internal gated turbs
cheers
What turbo is on there at the moment?
Could probably save yourself a bit of money finding another damaged or used one and pulling off the wastegate as opposed to buying a new gate.
TD04L off wrx... Yehhh i thought of reusing a oem wastegate, but than id rather just experiment with aftermarket as it makes tuning to peak boost better as opposed to the higher rated stock oem wastegate
Why not just get a simple replacement of a low psi rating, then let the boost controller do its job-
http://www.atpturbo.com/mm5/merchant...egory_Code=WGT
Kinugawa isn't bad a few friends of mine are running them on rb25's and rb25/30det's...
They seem to be relatively reliable. Hope this helps!
Hit me up with more questions and I can look into them further :)
I replaced the OEM piece of junk on my APS SR40/GT28 Turbo with a Garrett Actuator 445963-8 12204 40206
Works a treat but seemed pointless after E-boost 2 was installed lol
i've got the Kinugawa at 1.5bar, no issues at all.
