Ok this may sound stupid but i dont really know too much about cars... If a car doesnt have power steering is there anyway to get it installed? And if so how much would it cost approx?
in most cases it works out way too expensive to convert it ... $$$ :(
check your tyre pressures regularly - low pressure makes the wheel harder to turn at low speeds :) keep the pressure up to recommended levels
what raziel said :thumbsup:
Try not to dry steer.
Ie steer when / while you are moving.
the boss means " DONT STEER / turn the steering wheel more than a few degrees while the car is totally stationary."Quote:
Originally Posted by wynode
cost like $600-$1000 for adding a power steering, depends on what car.
you get use to driving with no power steering afterwards
the expensive part is the rack, all depends how cheap you get the parts. then labour,
