About to start to build something a bit different with a honda f20b
Car will be N/A
What's the redline "safe" will be running aftermarket cams and Ducati itb's
Recommended exhaust size? Aftermarket ecu?
Potential power?
Car will be N/A
Potential power?
2.5" or 3" exhaust
wouldn't bother raising the redline much
the ECU should be a preference of your tuner not people on the internet
i wouldn't expect much of a power gain either
Find yourself a good tuner and work with them on the setup and ECU choice.
Is this a transplant or no ?
Transplant/ custom build - RWD Mini
It's a fwd engine, similar in dimensions to the H22a
It was made for 2 litre racing based of the h22 - random info
Lol, and let me guess its built by honda?
You can use an adaptor and make do F2B meaning using a Bseries gearbox , which I would recommend as there are a lot of parts that I can supply to you to be used with any set up . Also from my understanding you are making the Mini RWD but are you installing the engine at the rear or with a mainshaft etc. ?! This will determine also the exhaust ! Size , length etc.
any reason why f20b?
