i read somewhere that info such as water temp was able to be displayed on the radio screen
is this possible or was i tripping balls??
did a quick search on here and couldnt find anything
Maybe if yu have aftermarket one youll see it the one with the gauge
champion!!!
Does it work if yu have a satnav??
Works fine with satnav.
I'll take one tomorrow morn if ya like.
I may have misinterpreted your post. If you meant if it shows on the satnav screen, then it doesn't. It shows up on the radio screen as described in the link above and pic below.
http://i44.tinypic.com/zthq8j.jpg
D1zzo, are you familiar with the satnav service menu? From memory,
Press cancel, setup and menu together and hold for a few seconds.
service menu should appear. Select the gps option. Press and hold menu button. You should now see gps speed (in mph) and other info about satellites etc. Can do this while driving...
