Tyre wear - Camber
Hi, I'm getting ridiculous camber wear on the inside of tyres.
I'm running after market wheels, stock suspension and height and have recently replaced all suspension bushes (wheel is very firm when car is jacked up)
Suspension is stock and is 15 years + could worn shocks cause camber?
I get heaps of body roll, saving up for coilovers atm.
Thanks.
More then likely your toe settings, go get another alignment, get a printout as well.
^as above, check toe and get a good alignment.
camber wont wear out tyres as fast as toe will
If you did not get an alignment, you dun goofed.
Definitely sounds like it needs an alignment, or the one you got was incorrect.
Get a printout and show us the results.
Camber starts getting nasty around 2-3 degrees IMO. I'm getting uneven wear with mild toe because my car is too low.
Sounds like yous are right, front left was +3mm and right was +0.2.
All good now, but I still have to get some new tyres.
Cheers fellas.
