Deatschwerks DW200 In-Tank Fuel Pump $140 incl gst
http://jdmyard.com/image/cache/data/...ph-600x600.jpg
Description
Introducing the DW200 in-tank fuel pump which has all the all the benefits of the DW300 in a lower priced, lower flowing package.
Flows 255 liters per hour (67 gallons per hour)
In-tank application specific fitment
Ethanol compatible
3-year no-fault warranty
Quiet and reliable turbine impeller
Universal pump kit includes:
2"x2" sock
Electrical connector
4" of fuel line
Miscellaneous hardware
Deatschwerks DW300 In-Tank Fuel Pump $215 incl gst
http://jdmyard.com/image/cache/data/...ew-600x600.jpg
Description
DeatschWerks redesigned the DW300 to offer greater flow with no significant increase in current draw. The new DW300 pump flows 26% more at its peak and 20% more on average. The low amperage draw minimizes pump temperatures, maximizes pump life and reduces stress on OE wiring.
The increases in flow were specifically engineered for high pressures (60-90psi), where forced induction applications need it the most. Conversely, fuel flow has been limited at low pressures (30-50psi) to minimize heat generation in return fuel systems. This dual zone approach results in a flatter flow curve, which maximizes both performance and reliability for supercharged or turbocharged applications.
The DW Advantage
Flows 340 liters per hour (90 gallons per hour)
Ethanol compatible
2"x2" sock
4" of fuel line
