		BC Coilovers
		Hi Everyone,
 We have been selling a lot of the BC coilovers recently and we thought it would be a good time to do a sale on the BC's. We havent had any big sales for the last month so we thought why not do it on BC's.
 There are a couple of versions and we believe that the BC's are one of the best coilovers on the market currently for their price.
 http://i1086.photobucket.com/albums/...ps6a4f342e.jpg
 BC V1
 The BC V1 Design VM Coilover Suspension Kit features 30 levels of Damping Force adjustment with Full-length height adjustment allowing extremely low ride height. The V1 Design VM Series Coilover Kit includes Rubber Upper Mounts in the rear. OE Front Upper Mounts are retained and re-used. This is designed to meet the needs of drivers who look for the ultimate balance between optimal performance, pure comfort, and a smooth and forgiving ride quality.
 Standard Features:
 - Front Rubber Top Mount
 - Rear Non Top Mount
 - 30 Level Damping Force Adjustment
 - Height Adjustment System
 - Anodized Alloy Casing
 - CNC Machined
 - T6061 Alloy Locking Ring
 - Monotube Design For Maximum Performance
 - Fully Rebuildable
 - 12 Month Warranty
 http://i1086.photobucket.com/albums/...ps502a0fc7.jpg
 BC BR
 The BC BR Type RS Series Coilover Kit features 30 levels of damping force adjustment, combined with full length height adjustment allowing an extremely low ride height, and pillowball upper mounts.
 The BC BR Type RA Series Coilover Kit comes with Pillowball upper mounts in the front, and rubber upper mounts in the rear, combining the properties of both types of upper mounts. This setup is designed for drivers who look for the ultimate balance of comfort and superior performance, coupled with a smooth and forgiving overall ride quality. This makes the BC BR Type RA Series Coilover the ideal choice for street, circuit and tarmac rally use. For most of those vehicles equipped with McPherson Struts, the front pillowball upper mounts are automatically upgraded to Camber adjustable upper mounts.
 The BC BR Type RA Series Coilover Kit utilizes enlarged shock absorber cartridges with specially designed shock pistons and rods to provide a broad range of damping force. The newly developed lubricant oil used in all BC Racing shock absorber cartridges assists in minimizing aeration and cavitation. The beveled edge design on the lower locking ring ensures and optimum seal with the lower mount and prevents the lower locking ring from unseating.
 Standard Features:
 - F: With Camber Adjustable Top Mount
 - R: With (or Without) Rubber Top Mount
 - Enlarged Cylinder & Newly Developed Piston
 - Exclusively Designed for Each Application
 - CNC Machined
 - SAE9254 Steel Racing Springs
 - Fully Rebuildable
 - 12 Month Warranty
 http://i1086.photobucket.com/albums/...psa05f2906.jpg
 BC BR Type RH
 The BC BR Type RH Series Coilover Kit features 30 levels of damping force adjustment, combined with full length height adjustment allowing an extremely low ride height, and pillowball upper mounts.
 The BC BR Type RH Series Coilover Kit comes with Pillowball upper mounts in the front, and rear, combining the properties of both types of upper mounts. This setup is designed for drivers who look for the ultimate balance of comfort and superior performance, coupled with a smooth and forgiving overall ride quality. This makes the BC BR Type RH Series Coilover the ideal choice for street, circuit and tarmac rally use. For most of those vehicles equipped with McPherson Struts, the front pillowball upper mounts are automatically upgraded to Camber adjustable upper mounts.
 The BC BR Type RH Series Coilover Kit utilizes enlarged shock absorber cartridges with specially designed shock pistons and rods to provide a broad range of damping force. The newly developed lubricant oil used in all BC Racing shock absorber cartridges assists in minimizing aeration and cavitation. The beveled edge design on the lower locking ring ensures and optimum seal with the lower mount and prevents the lower locking ring from unseating.
 Standard Features:
 - F: With Pilllowball Top Mount
 - R: With Pillow Top Mount
 - CNC Machined
 - Fully Rebuildable
 - 12 Month Warranty
 BC ER
 The BC ER Series Coilover Suspension Kit features 30 levels of separate rebound and compression damping force adjustment, full-length height adjustment allowing extremely low ride height, and external reservoirs. The BC ER Series Coilover has been especially designed and developed to meet the demands of the serious driver for professional competition use. Its external reservoirs allow more oil to be contained than a conventional coilover, to slow down oil temperature increase.
 The separate compression adjustment provides a wider range of tuning settings than a traditional coilover, in which only slight changes occur to compression when adjusting the rebound.
 The BC ER Series Coilover offers complete adjustment for the individual that demands serious performance and wants to fine tune their suspension setup to their needs
 BC ER Series Coilover Standard Features:
 - Front External Reservoir
 - Front Pillowball Top Mount
 - Rear External Reservoir
 - Rear Pillowball Top Mount
 - Twin Piston Design
 - Separate Compression & Rebound Adjustment
 - Full-Length Height Adjustment
 - CNC Machined
 - Fully Rebuildable
 - 12 Month Warranty
 http://i1086.photobucket.com/albums/...pse9c1656c.jpg
 Prices are:
 V1 - $1150
 BC BR RS - $1250
 BC BR RA - $1300
 BC ER - $1650
 These are delivered.
 Any questions contact us on sales@wolfracingproducts.com.au
