Just wanted to know if the oem rta toe is adjustable or not as I didn't pass vehicle inspections coz of this and afaik this item hasn't been changed in my car only when a hardrace toe kit replaced it but since then has been taken to pass rwc
Who's gonna certify this for me via letter or whatever so the suckers can pass me for rwc(suspension store/Honda?)
the oem compensator arm is fixed, it's toe 'adjustable' because when it loosened, it can slide around in the bracket (changes toe).
hardrace is adjustable on the compensator arm itself, which is why it wont pass rwc.
on my list of things to fix it states
'Rectify rear trailing arm toe adjuster to be removed'
It's a stock one in there already? How am I meant to prove it is to them?
Pic of rta assembly. Sounds like the guy doing the inspection is a retard.
might be like this
http://i180.photobucket.com/albums/x...STtoearmin.jpg
That photo shows perfectly that there is already adjustment available in the factory setup (the slotted hole at the upper right of the picture). If the inspector doesn't like the fact that you can adjust the rear toe, then he'd better defect every single EG-EK Civic (plus no doubt dozens of other models).
If you have an adjustable linkl as shown in the pic, then he might have a problem with it. Still, it's only adding adjustability to where there already is adjustability from the factory, so hou could he have a problem with it?
Solid (rose joint) end links are another matter, and generally illegal
i removed my hardrace adjustable toe from my ek... leaving the factory item back in place with the adjustable bolt area still showing like the pic above ^
