Hey all,
Anyone know the ECU code for 98 Accord with a F23a.. specifically the code of the manual ecu (but auto is ok-ish). I think they are OBD2A ecus.
cheers
Hey all,
cheers
Go and find the ecu it should be located in the passenger footweel compartment and will have it's part number on it
Are you looking to replace it?
The 5th gen accord VTEC Auto ecu part number was **** POA **** - look for the middle three letters/number to distinguish yours
Or take it to a wrekcer to get matched up
Do you have the Auto ECU ?
According to some source the ECU for the USA accords is ***** PAA ***
Wether or not this equals ours - i don't know
I'm sure with ECU-MANS help you can convert the auto ECU to a Manual one
to spill the beans... I am trying to convert an RA3 Odyssey which only came in Auto. ECU for that is PEA-Q50.
Because it was only ever auto there is no equivalent manual ECU variant.
It has a F23A OBD2A. All 5th Gen Accords are F22 and OBD1. 6th Gen accords came in F23a OBD2A (PAA-L10 i believe) and OBD2B (PAA-L11 I believe).
There are a few other cars in Japan that came with F23a.. CF6 and TA1 from research.. seems TA1 was only auto though..
These are just my findings so far.
I gotta goto honda for a rear main seal, might see if i can get the code from the EPC. But input is appreciated. :p
Whoa sounds like a nice project
The facelift 5th gen accord did come with OBDII
I think you can change your ecu to a manual be desoldering a few things on the cirucuit board and wiring in the neuteral safety switch
No need for new ecu
I'm sure ECU MAN will know more
As i've been researching an auto to manual swap too
Maybe an ODBII to ODBI conversion harness? :P
Good luck
