Need someone to clarify something regarding EK1s / D16Y4s OBD and Engine Loom
Hey guys and girls,
Usually I just lurk here and don't ask anything as all the info is pretty much here already.
However, after hours and hours of trawling threads over a looooong period of time now, I've not found any definitive answers to this one question.
This might end up really long, so apologies as I tend to dribble crap.
Okay so first off a bit of back story, I have two EK1's, one which is a pre facelift GLI daily which I have done a B16A2 swap into and another which is a facelift CXI, which I plan to do a B16/18 Frankenstein or B20V swap into as a track car.
Now here's my issue, when I did the B16 swap into the pre facelift, I again looked for hours trying to find what the D16Y4 of that years OBD standard actually was, some said OBD2A, some said some weird standard between OBD2A and OBD1.
I finally just chanced that it was OBD2A, bought an OBD2A engine and loom and it all went in beautifully, plug and play, no issues.
Now, I'm getting ready to do the swap on the facelift EK and again, I'm having trouble figuring out what this cars OBD standard actually is.
I know lots of people will just immediately jump out and say "Facelift EK's are OBD2B" and yes, while all the information posted on American sites will state that, I'm not sure I believe it to be the case for a few reasons.
Mainly after comparing the looms, ecu's and many of the connectors which would usually be of help to determine the OBD, I found that between both my pre facelift and facelift they in fact share identical looms with only very minor differences, things such as 4 wire O2 sensor as opposed to 1 wire on the pre facelift.
Other reasoning being that I know for a fact that many AUDM models were slow to receive OBD2B, as I have a 2001 Accord, 2000 Legend and 2000 EK1 none of which are OBD2B nor sport an OBD2B connector. However by American rationale, by 2000, all should have.
So is it in fact the case, that all EK1 D16Y4's are this weird middle OBD standard? Both pre facelift and facelift?
And if that is the case, should that then mean that due to the looms being 98% identical, OBD2A is the correct swap loom to use? Considering I have used an OBD2A loom in the pre facelift?
TL;DR
Are all EK1 D16Y4's actually some weird OBD standard, can I use an OBD2A b series loom on a facelift EK1 considering the D16 loom is essentially identical to my old pre facelift D16 loom.
Shit that was longer than I wanted.
Hopefully it made some sense.
Cheers. <3
