EP3/FN2/DC5S brakes fit on an EG Civic?
Sorry to ask a noob question. :( I'm just wanting to check that EP3R or FN2 front brake calipers should bolt right up to an EG as long as you:
- grind 3.2mm off the caliper brackets OR fit 3mm Spoon or JDMyard spacers behind the rotor
- use a EP3/FN2/(DC5) rotor (300x25, height, ~64mm bore, an RSX-S rotor for yanks) that's redrilled to 4x100
So this should give a cost effective brake upgrade that fits under 16" wheels; and it seems better than running 282 DC2R or 266mm DC2 brakes on an EG, in theory. :)
Have I got this right? :)
http://honda-tech.com/suspension-bra...egras-3044628/
http://honda-tech.com/suspension-bra...tegra-2760281/
http://honda-tech.com/acura-integra-...grade-2169149/
[My understanding is that the S2000 front calipers are the same as the EP3/DC5S/FN2 I think? With a RSX Type S rotor being required to use s2000 calipers, as the S2000 takes a somewhat different rotor. So using ep3r/dc5s calipers instead of the rarer s2000 ones should be no issue.]
