Just wondering if there are any differences in suspension or engines between 1994 vtirs and 97-98 vtirs(before the update)?
Also, would anyone know if dc2r suspension, sway bars ect. will all bolt up to a vtir or are there different mounts?
no engine or sus changes as far as i know..
minor changes before the second series such as adriatic blue replaced the dark grey colour, intro of the aqua colour in 96 etc
in the dash instrument cluster the brake symbol is diff...
also the side mirrors in 96 was updated - has like a crease or whatever u call it going across it.. also drivers airbag standard on GSi
if u looking at the GSi's motor, the rocker cover had changed in 96 with a smoother look and no "H" on it just "honda motor co."
the type R suspension uses a ball joint on the rear sussy so you need the lower control arms of the type R to get the sussy to fit. the fronts are the same i think =P...
Quote:
Originally Posted by vti-r teg
suspension will be exactly the same for GSI , vtir from 94-2000. ( dc2 / dc4) Both shocks , springs , fornt and rear swaybars should be able to swap around etc.
For ITR suspension , the REAR shocks use a ball / bush joint and a different lower control arm . IT will fit a DC2/DC4 , but you will need EG6 / ITR rear lower control arms.
Also , a ITR swaybar wont be adviseable to fit on a vtir/gsi - just get an aftermarket one with a reinfocement kit such as WHITELINE.
hey benji is the EG6 got the same lower control arms as the ITR ?
