Track day warriors which transmission oil are you running and why, price / quality and are you changing it often.
Many thanks
Many thanks
Standard Honda mtf is fine, no need to get anything racing specific.
Never had any issues using it, shifts well during track events and after on the street.
My transmission has done 280k on the street before taking it to the track and still shifts fine and no gear whine or rattles to be heard.
I changed mine before I first tracked it then after a few events when I did an engine build, only changed it because it picked up dirt and muck when I was draining it but it came out looking as new otherwise.
I've heard of some people adding compressor fluid. works a charm
When I was running stock ITR transmission I used Penrite pro gear 75w-85. It seemed to give the best shifts all round.
I used to change it before every track day, it cost something like $50 for 2.5L
It's viscosity and grade (GL4) are suitable for Honda transmissions and it supposedly has good shock resistance compared to OEM and similar fluids.
I'm only using motul FF LSD type 2 now because I'm running different internals and LSD settings.
What gearset u running tim
