Motul – FindMyOil – Ford Falcon XR6 Turbo
http://i762.photobucket.com/albums/x...0Australia.png
http://i762.photobucket.com/albums/x...bo%20-%201.png
(Photo source: Wikipedia)
The car that received Motor magazine's Bang for your Buck 2008 award, Ford’s XR6 Turbo first introduced its updated Falcon lineup with the Series II update in October 2006. The BF II turbo models had an engine upgrade and came with the same engine as the FPV Typhoon internally, with the only difference being boost pressure, with the XR6 Turbo running 6psi boost pressure and the FPV, 9psi.
The turbocharged engine used in the XR6 Turbo and G6E Turbo models produces 270kW (360hp) and 533Nm (393ft-lbs) torque.
Knowing what lubricant to use in any model you have is easy. Just go to www.FindMyOil.com.au and either type in the make and model into the quick search bar or search using the drill down function.
Here’s how to find the right Motul oil for your car:
http://i762.photobucket.com/albums/x...bo%20-%202.png
The same features of refill capacity and recommended product are found in the Manual Transmission, Automatic Transmission and Differential sections.
In some cases there is a note “Refer MOTUL”. This is either due to a change of equipment mid-model or certain requirement for using Motul in this compartment.
http://i762.photobucket.com/albums/x...bo%20-%203.png
Almost all OEM’s do not keep a record of the volume required for a full flush of the braking system. So in the case of the Brake fluid section, only the recommended product is displayed:
http://i762.photobucket.com/albums/x...bo%20-%204.png
The Radiator section may have 2 or 3 refill capacities depending on the models being viewed. This is due to variances between Auto and Manual models. Motul recommends going with the larger volume to be sure you have enough.
Also seen here is a reference to a note: “See note 1840 below.” It is important to always check the note!
http://i762.photobucket.com/albums/x...bo%20-%205.png
Here is the note section, found at the footer of the recommendation list:
http://i762.photobucket.com/albums/x...bo%20-%206.png
Save yourself time and cut out the guessing game when it comes to your regular service. Make sure you have the right Motul fluids and volumes for your car with FindMyOil.com.au.
WHERE TO BUY: Motul Australia - Dealer Locator
Looking for the right oil for your car? Easy! Go to www.findmyoil.com.au*
*Findmyoil.com.au is for OEM recommendations only. For modified vehicles, consult your tuner or contact Motul.
Stay connected with
- Motul Australia – Cars Facebook Page
- Motul Australia Website
- Motul on YouTube
We’re here to help!
Can’t find an authorised reseller near you? Any questions on queries? Let the Motul team know. Send us a PM!
If you have any questions about any of our products please feel free to get in contact with us.
