My 02 Odyssey has a bit of a sticky throttle cable.
How do I remove the cable at the pedal ? so I can get the cable out and get some lube into it.
I found a mechanic who told me to squeeze the back of the white plastic cable end. It has tabs that lock into the top of the pedal.
Only a matter of undoing two nuts then to remove from the inside.
let us know how u go !
It went well.
I hung the cable up by its bracket then repeatedly sprayed Inox into the top and worked the cable inner up and down.
Eventually, the bottom end of the cable became wet with the Inox and a heap of black muck came out with it and wiped it off with a rag.
I continued to spray until only clear Inox came out.
Now it's back on the car and is much easier to press the throttle and as smooth as silk.
Nice one! Well done.
