Have a read of this thread....might need to sign up if you aren't a member.
Not sure regarding the ECU, you have aftermarket anyway right? There is a separate Abs control module, someone else will need to confirm whether there is any feedback to the ECU.
Try unplugging the abs control module or removing an abs fuse to see if it has any affect. I know I have run with the Abs disabled on my dc2 (obd1 running hondata) with no malfunction noted.
Grant's DC2
http://forum.clubitr.com.au/showthread.php?t=14421
