		civic eg po6 ecu problem
		Hi all, does anybody know som1 who can repair ecu in nsw? my current ecu for my civic eg d15b7 efi has a majour delay starting. i have narrowed it down to be the ecu not grounding the main relay fuel pump signal and have confirmed it the ecu as wen i manually apply ground on the main relay the fuel pump will prime. i have borrowed another po6 ecu and it works fine but would like mine repaired if possible.
		Google QM3 repair, if you have some soldering skills you can likely tackle this one yourself and save some money aswell as gain some repair skills. Good luck
		I can fix this ECU for you, PM me for more details.
