Intake Manifold Cover - Re-painted
Thought I'd write up how I painted my intake manifold cover for my 2007 Honda Accord Euro 2.4 K24A3.
https://uploads.tapatalk-cdn.com/201...1b4fed9fcd.jpg
This is the stock.
First thing I did was take the manifold cover off, by removing the 2 x 6mm nuts and pulling the cover off carefully. There is a plastic clip on the middle that holds it in.
I then masked up with electrical tape the i-vtec 2.4 and the bolt holes.
https://uploads.tapatalk-cdn.com/201...bda60a5015.jpg
I used caliper paint as it is high temperature resistant.
I used steel wool to scratch the paint slightly to make the paint stick better.
I then took it outside and did 4 coats
https://uploads.tapatalk-cdn.com/201...f5f012a6e2.jpg
I didn't have any clear coat at the time, so I removed the masking and put it onto the car.
Unfortunately I lost one of the 6mm nuts that hold it in place :(.
When I took the masking off there was a bit of over spraywhere I didn't want it, so I got some Supercheap auto degreaser and used a q tip to rub the paint off.
https://uploads.tapatalk-cdn.com/201...cb2d7c98ce.jpg
The next day I Went to supercheap and grabbed some high temperature resistant clear coat paint.
I then scratched the paint slightly again, did another 2 coats of the caliper paint, then waited about 20 minutes and did 3 coats of clear coat.
https://uploads.tapatalk-cdn.com/201...921a021407.jpg
Then I put it back, and it looks bloody awesome.
Really happy with this mod, takes about 30 minutes to paint. Super easy.
Sent from my Pixel XL using Tapatalk
