Coolant temp sensor faulty?
So ive started diagnosing and tidying the car up. Got a code 6 which is coolant temp sensor. Ive tested the one under the dizzy which i am lead to believe is the one that trips codes. It works fine.
the issue i seem to be having is the temp gauge never really gets hot it sits around 1/4 i pulled the sensor out of the thermostat which is for the fans i understand and i cant get any kind of reading out of it with a multimeter. Is it stuffed? Could this also be a reason for a code 6?
I did notice the fans switch on fairly often and stay on for quite a while. Thanks for your help
