Spot the (stealth) Shift Light!
http://www.racinghonda.com/pictures/...DSCF6514_1.jpg
Given up? Well its the little LED in the middle of the centre air vents. Its kinda in the peripheral vision.
http://www.racinghonda.com/pictures/...DSCF6512_1.jpg
It was really easy to hookup, it has a memory. So all you have to do to set it is rev the engine to the desired RPM and press a button on the control module of the shift light.
The LED is very bright and you WILL notice it lighting up. I have set it to light up at 6400rpm. It works perfectly too! (after some fiddling around).
Only 3 wires are needed. 1 for 12v, 1 for earth and 1 for the ignition signal pulse which I wired into the ECU harness (igniter wire).
"What? no officer, I have no idea what that LED does. It was already there when I got the car. Might be from an old alarm?" :D
