Hi, I would like to ask if all EK4 comes with sway bar or not? thanks
yes they do
Yup front and back.
even on gli model?
wat i'm askin is i've got an LXI which is same as GLI, and i brought some sway bar from EGSI, and the package of the bar said it's a replacement bar so i don't know if my car has a bar for me to replace or not..
EK4 and EM1( b16a powered vtir coupe) came with front and rear swaybars. AFAIK all other EK variant came with only front end swaybars.
ok so all other EK need special mountin to get the sway bar to be fitted?
you can use the STOCK ek4/em1 mounts to fir a STOCK swaybar - or get special reinforced mounts to fit a larger bar.Quote:
Originally Posted by Nodachi
THIS below is the whiteline upgrade to suit EM1 - should be very similar /same to one for a EK4 , or any other EK.
http://i7.photobucket.com/albums/y28..._/DSCN2139.jpg
