hey i have a toda timing belt in my b18c and its done around 4000 ks now,how long does the toda timing belt last for?all my internals are stock except for JDM b18 pistons.any advantages having the toda belt? cheers.
No advantage really over OEM one.
No power gains , just to match up with more agressive cams if you do install em.
stronger....
last you may b 40-50k km...
Toda high power timing belt (vs. standard belt)
· Resistance to cutting: Approx 3.5 ~ 4 times
· Heat resistance: Approx 2.5 ~ 3 times
· Tooth integrity: Approx 3.0 ~ 4 times
· Resistance to abrasion: Approx 2.5 ~ 3 times
The standard belt is due for replacement at 100,000km.
The TODA belt should be replaced at the same interval.
This will maintain it's superiority over the factory timing belt.
Best used on vehicles with aftermarket camshafts, valve springs & increased rpm.
sweet my engine is stock but atleast i got sumthing that is toda in it :D lol
