Is there a problem with my clutch people?
Everytime I clutch in, I hear it "squeek". But after a few minutes of clutching, it goes away.
Any explaination? Major problem? Need oil somewhere?
Squeek is starting to pee me off :x
Sounds like you need to lube your slave cylinder rod.
how do u do that.. use WD40???
or should i put some oil there??
Ken
I had a similar problem.
But when i pushed my clutch in it wouldn't do anything, it just flopped and it took me about 5-10min of pumping to actually get any response from the clutch pedal. I took it to the mechanic, he adjusted some nut and i haven't had the problem since, although I don't think it is "fixed".
slave cylinder. there is piston in slave cyclinder that dries out you can lubricate over and over or replce the whole cylinder.
hm...can this be done at home? Or better to bring to mechanics?
I have the EXACT same problem! :xQuote:
Originally Posted by BlakTegra
Sorry that doesn't sound similar at all? :?Quote:
Originally Posted by soul4real
I've tried wd40 in the slave cylinder, doesn't do it for me...
-az
Well mine did squeek as well :)
So it wasn't totally irrelevant.
