Honda Prelude Model Info
NOTE: The specifications listed below are only estimates and to be used to gain a rough idea. OzHonda in no way guarantees their accuracy and is not responsible for any errors that may have been posted.
Honda Prelude VTi-R:
Released: 1997
Engine code:H22A4
Engine description:Four cylinders, in-line, belt-driven DOHC, four valves per cylinder, all alloy, cross-flow head, balance shafts, VTEC variable valve timing.
Power:147kW @ 7000rpm,212Nm @ 5250rpm
Cylinders:4
Valves per cylinder:4
Engine orientation:Transverse
Variable valve actuation:timing only
Stroke (mm):91.0
Bore (mm):87.0
Head material:Aluminium alloy
Block material:Aluminium alloy
Configuration:In-line
Engine location:Front
Valve train: DOHC
Capacity (cm3):2157
Transmission:Synchromesh five speed manual/4speed automatic
Maximum torque:212Nm @ 5250rpm
Maximum power:147kW @ 7000rpm
Compression ratio:10.0:1
Models: 2door coupe, (1999)model. $1,500 leather trim option for the VTi-R, 2. Improved power output for the 2.3 litre VTEC engine in the VTi-R up by 4kW to 147kW
Honda Prelude Si
Released:1997
Engine:Four cylinders, in-line, belt-driven DOHC, four valves per cylinder, all alloy, cross-flow head, balance shafts.
Code: F22Z6
Power:118kW @ 6000rpm,201Nm @ 5200rpm
Weight:1218kg
Brakes:Front brake description:Ventilated discs, 282x23mm
Rear brake description: Discs, 260x9mm
Rear - diameter (mm):260
Front - diameter (mm):282
Features:Power steering,Central locking,Electric mirrors,Electric windows,Remote central locking
Models:2door coupe
Honda Prelude Vti-r(4th Gen):
Released: 1994
Engine: H22A1 Four cylinders, in-line, belt-driven DOHC, four valves per cylinder,all alloy,cross-flow head,balance shafts,VTEC variable valve timing.
Power:142kW @ 6800rpm,212Nm @ 5250rpm
Transmission:5speed Manual
Weight: 1325
Features: Power steering,Sunroof,Cruise control
Models:2door coupe
Honda Prelude S:
Released:1991
Engine:F22A1,Four cylinders, in-line, belt-driven SOHC, four valves per cylinder, all alloy, cross-flow head, balance shafts
Power:96kW @ 5200rpm,191Nm @ 4000rpm
Transmission:4speed-Automatic
Weight:1245kg
Brakes:brake description:Ventilated discs
Features:Power steering,Sunroof,Cruise control
Models:2door coupe
Honda Prelude S:
Released:1991
Engine:F22A1,Four cylinders, in-line, belt-driven SOHC, four valves per cylinder, all alloy, cross-flow head, balance shafts,
Cylinder:4
Transmission:5speed manual
Weight:1220kg
Features:Power steering,Electric windows,Cruise control
Models:2door coupe
Honda Prelude Si:
Released:1991
Engine:H23A1,Four cylinders, in-line, belt-driven DOHC, four valves per cylinder, all alloy, cross-flow head, balance shafts,
Power:118kW @ 5800rpm,209Nm @ 4500rpm
Cylinder:4
Transmission:4speed auto/5speed manual
Weight:1290Kg
Brakes:Front brake description,Ventilated discs
Rear brake description,Discs
Features:Power steering,Sunroof,Alloy wheels
Honda Prelude Si(4WS):
Released:1990
Engine:B20A6 - 106kW @ 6000rpm,174Nm @ 4500rpm
Cylinder: 4
Transmission:5speed Manual,4speed Auto
Weight:1130Kg
Brakes:?
Features:?
Released:1987
Engine:B20A6
Cylinder:4
Weight:1175kg
Brakes:?
Features:?
2.2 lt engine.. otherwise nice info you have there!
i thought the comp ratio for the h22a was like 10:8:1 and it was a 2.2 litre.
I may be wrong tho lol.
good info anyways.
H22a's are 2157cc, and have a 10:1 compression....
Nice info, the power figures for the series 2 gen 3 are also correct for the series 1 if u wanted to change that :)
Sticky?
anyone have more information?
