Hi, I wanna change my fuel filter, does anyone have a DIY guide for it. And also so is the fuel filter in the engine bay or near the petrol tank?
Its in the engine bay. Looks like a little black tin can.
http://www.honda-tech.com/zerothread?id=374586
Thats for a teg buts its all the same shit nowadays.
the location depends if you have a fuel injected engine or a carby
if its carby: on the fuel tank, look under
if its fuel injected: its in the engine bay
thats just so helpful.Quote:
Originally Posted by zoopsta
sshould be next to the brake and clucth cylinder on the right
around the cornerQuote:
Originally Posted by z3lda
in your EG civic , it is located next to your brake booster . IT has 2 fuel lines inot the top. Its the size of a oil filter.
ok cool, so its under the fuel tank, i got a carb. Is it hard to change?
how do u know if u need to change it.. last time i serviced my car i was gonna change it but then realised it was approx $60!!.. whats the benefit of changing it?
dunno i guess cause i'm not getting enough k's per tank, it could be a diff prob altogether, but i'll try it and see if it improve's my fuel ecomi.
whens the last time you replaced your spark plugs?
ive read around and people have suggested the fuel filter be replaced every 20,000kms or so.
Quote:
Warning. Use this information at your own risk. I nor OzHonda take any responsibility in your misinterpritation on this information
89 Civic has the fuel filter mounted on the fuel tank , if you safley jack up the car and take the Left rear wheel off, look at the fuel tank and you will see some orange /red fuel lines going to the filter which is hiding under a plastic cover. the plastic cover has two plastic clips holding it on, then with that removed you will se the fuel filter, its advised to clamp off both lines to prevent fuel spillage. undo the filter hoses by pulling the hose clamps back then pulling off your hoses, take note how the filter came off as they are directional. put the new filter on in the revers way you took the old one off, make sure the fuel lines and clamps are on correctly and put everything back together. start the engine and look for fuel leaks. there is also another filter in the engine bay mounted on the manifold, just follow the fuel line.
i changed the sparks (OEM) a about a year a go, why? Do the sparks effect fuel comsumtion as well?
Well according to what other people have said, the general consensus is yes it does. How many km do you travel a year?
