spark plugs
hey guys, i have a 94 civic vti d16y auto and i need to change my spark plugs. i asked honda and they sell the ordinary platnium spark plugs for 4 buck each
then i saw these iridium ngk spark plus. repco sells them for 20 bucks each/ auto1 sells them for 15 bucks each
do they really make any difference, ive got a auto, d16 vtec. will i feel any difference in power and in economy, are they worth getting
thanks
bkr6e-11
ask for em at repco. change em every 15-20k.
~$4 each at repco.
what about the iridium sparks, is it worth getting, they say it lasts 80-100,000 k
everyone will give you a different answer. Many say the iridiums are the best (maybe cause they paid $20 a plug), where as others swear the standard are just as good, but require changing more often. I use the cheaper NGK plugs and have no reason to complain.
NGK BKR 7e-11 - best plug for all B D and H engine ;) replace them every 2500km. period.
Regards James
ive got 4 x new BKR 6e-11's (because ^^james^^ insisted on 7e11's when my car was tuned..!)
u can have all 4 6e-11's for $5 if u r in brisbane. they are fine for an auto d16y
The spark plug has two primary functions:
To ignite the air/fuel mixture
To remove heat from the combustion chamber
A common misconception is that changing spark plugs will result in a large power increase. In most cases, removing even seriously worn out spark plugs will only result in very modest power gains, typically about 1-2% of total engine output. This could be even less for computer-controlled vehicles, primarily because most newer vehicles have more powerful ignition systems and the vehicle's computer can make adjustments so that vehicle operation seems smoother and more seamless.
What Iridium plugs have in advantage is
Long service life. around 60,000kms (not the so claim 100,000)
Extremely good ignitability and a stronger spark
Fuel Efficiency
Most new cars uses the iridium 0.8mm as it increases the Fuel Efficiency but with an increase of only a few %, I doubt you can feel the advantage of better
power, acceleration, response etc. On older cars you will be able to feel it.
Hi there...
I found this to be goo reading on Spark Plugs;
NGK Information on spark Plugs
There are different materials like copper, irridium etc... Some people swear by either. You'll get mixed opinions on spark plugs. If you go the perfomance route you might consider changing your leads as well.
Not sure what I would do so maybe this will be no help at all :)
Iridiums are pretty good. :thumbsup:
iridums are crap. plugs are better changed every 15-20k. much better.
stock rocks. :thumbsup:
unless ur toting a diff engine setup, just get stock man.
