Does anyone know how to adjust/tilt the headlights for the Euro? Are the Hi/lo beams all one adjustment, or can we mannually adjust each one. I tried looking in the mannual, but it says to leave it to the techs.
If they're HID they auto adjust..
why would u want to tilt them any further?
I have a standard. I wanted to adjust them. I opened the bonnet thinking "this will be simple" and I could NOT work out how to do it.
Can someone guve me a basic run through for the standard euro? Please?
I think the instructions for adjusting headlights are in the manual.
Nope - I have a standard, and the instructions are not in the manual.
I have a standard too. It tells where to put the screwdriver to adjust, and how to calibrate the height. In the section for HID (lux), it says that you cannot adjust. Mine is a 04. I'll scan the section in tomorrow so that you can use it.
Edit: I was mistaken. The headlight adjustment section is not in the manual. I saw it in a Honda repair procedure. I'll look for it at home and post it up.
Here you go. You can only adjust for vertical aiming.
http://img210.echo.cx/img210/5022/04...dlights5cu.jpg
