hey der pplz
just wondering anyone out there know any info on the f20b please let me know.. i tried ringin a few honda places but there clueless..so yea.. post any info on em, such as.. Wiring diagram would be awesom..
hey der pplz
....anyone ? gotta be some honda wiz out there
The sensors etc.. would be identical if not similar to a H22A, however if your going to use the F20B ecu, I havent seen one ever so I wouldnt know what the pin outs would be like. Maybe a picture would be helpful?
Otherwise convert the loom to run a OBD1 ECU and use a P28/P30 or a P72 ECU. Get it remapped or i highly recommend you get real time tuning such as PROECU or Hondata that will work with those above ECU's
u know where i can get wiring diagram ? any tips on the mounts and reloacting parts ?
F20B SIR-T into a EK
http://www.honda-tech.com/zerothread?id=1278946
FAQ H22A into a EG/EK
http://www.honda-tech.com/zerothread?id=650329
Plenty of reading material
so you rkon the h22a wiring diagram is simular to the f20 ?
h22a and f20 are very very similiar.
hey there.. yea thanks.. i knew they were simular.. are the cams the same ?
wats the power of a f20b to a h22a which is more horse power
I think both engines make 147kw standard.
im still after some mounts..
