Radiator woes for an ED
The piss weak factory radiator has split the top tank and after inspecting the rest of it, I decided to junk it. What I need to know is, can I fit a DA Integra radiator or is there anyone who makes alloy radiators for this shape??
At the moment, EG onwards is the only alloy ones I can find! Prefer not to fit a standard core cause it is less than ideal. Anyone retro fitted a EG core to an ED? Does it fit?
If not I may have to resign myself to the thicker standard Integra core, sighs...
Thanks in advance
your piss weak factory radiator probably lasted 10 years.
normal life for plasic tanks is about 6 to 7 years, which i think is quite impressive. Just fix up your factory radiator, it will be good for another 6 years if done right, and correct coolant is used
