just a quick question: i know it comes out of a CRV but how much kws? and why would u use it before a b16a or b18c?
It has more torque for starters
read through the other posts on this topic, there is loads of info on this.
108kw
200nm
the idea is to use a b16 head on it for big power
basically bigger capacity = more torque........but the crank doesn't let it rev out as much (reliably)
HP = torque times by rpm (basically)
By using a 2 litre block and increasing the torque of the engine and a b series vtec head to allow the engine to rev higher quite simply you end up with more horsepower.
Wynode from what i have read with the correct rod/piston choice the rod/stroke ratio is close to optimal which denotes reliable high rpm operation as the r/s ratio dictates where the force is being placed on the cylinder walls.
Although an ITR crank is the best choice as Toda_AU has stated in previous posts.
Problems that people run into with high rpm reliablity are due mostly to the inherent weak casting/cylinder sleeves of the B20 block although that is at extremely high rpm.
Go to www.hondaswap.com.au there is a wealth of information there.
