fan noise on EG civic
hey guys, tonite i noticed that when i turn on the ac/heat/fan theres a noise behind the glove box, (turn on a fan and hold a piece of paper in front of it so its touching it and thats what it sounds like). when i turn it off it slows down and then stops. what could this be? would i need to remove the glove box to fix something there? :)
lol, u prolly got something stuck in there from the engine bay (not using recycle)
jus getta air hose, and blow the fans lol. might help.
does the noise happen ONLY as you turn the fan or heater/ac on ? The noise gets louder the faster the fan is ?
I think you have some leaves or some crap stuck in the fan box ~ look under the passenger foot well , look up and there is the "fan" motor - use a 8mm socket or spanner and take the 3 small bolts out , the whole motor (looks liek a tiny washing machine) will fall out. Should be abit of leaves n stuff inside - clean out and reinstall.
hope that did the trick
thanks boys i'll give it a try tomorrow :)
problem solved, Close thread pls :)
great info ben it took me 2 mins to do, now u can hardli hear the fan :)
