Hello,
I am looking for a diy guide on installing el dials. I got a 99 ek. I have tried searching but nothing really tickles my fancy.
Thank you all
James
Hello,
Thank you all
James
can anyone at least tell me how to get the dash out? where the screws are etc etc?
Hi,
There should be 2 screws at the top of the black gauge cluster. Remove them and pull it out. Then you should see just the cluster itself. There will be 4 screws, 2 at the top and 2 at the bottom. After you have remove the 4 screws, the cluster would be loose. However, you would need to remove the wiring harness attach to the rear of the cluster. It is a bunch of colourful wires! I think there is a quick release latch. Unhook that and your cluster would be out.
Hope this helps. Cheers!
Regards,
Johnnie
