recently, my engine is running extremely low when stopped, about 200 rpm. Anyone knows what's wrong with it? :confused:
um on my ek1 myn only drops down to 100rpm wen aiir con is on and ive stopped n giv it a lil rev.
but normall 1000rpm
that sounds weird to idle at 200rpm
probably your idle control valve. theres plenty of posts about it. give it a clean and see how you go. have a search and see what you can find.
search it mang...
there are plenty of useful shit that ul find...
genrellly its ur idling position sensor thing...
possible leak in a vac hose
Bad Spark Plugs could be the cause. Or possibly a distributor problem.
Try shorting the ECU plug and look up the error code(s) if any.
if its a sudden drop in revs....IMO search either electrical or vaccuum connection is loose. Look aroudn your engine bay for any loose groundings ( off block , gearbox , thermostat , battery etc) or check all pipes around the inlet manifold are secure.
Good luck!
EDIT also try my ECU check for codes...
http://www.ozhonda.com/forum/showthread.php?t=9846
For a quick fix method, adjust your throttlebody according...
