Need a little help with installing my JDM mirrors. Anyone have them installed and willing to help with a wiring schematic or just description as to which wire does what? All help is appreciated. Thanks
if your current dc5r has electric mirrors already, all u need to do is swap them over. its that easy isnt it?
Yea, but JDM mirrors are folding mirrors.
I found out that the wires down to a few current are unknown ones. All wires between the JDM and AUDM is the same except ones with diff sockets and unknown func. The switch has 2 unknown wires comin out which i think is a power and switched on signal wire.
If anyone has install the JDM folding mirrors in please let me know. Thanks.
Manage to find some help and till then I am able to wire the mirrors in with just the switch to control it, but that would defeat the automatic folding feature that should be controlled by the relay, which I assume from reading. The relay is a solid state controlling device that has only 4 wires going to it. The relay itself has 5 pins, but looks to not have the 5th connection in use (pin 2 on the connector). I'm sure that Honda uses the relay, or other similar ones that are wired the same for other functions, but unfortuneatly havn't found anything yet, or similar. Anyone who knows more about Honda relays will be of a help, but until I hear of anything else, I will have to do more research.
