are the rotors pressed on to the arm or are there screws to hold it in place..
how would you change rotors on an eg?
front ones that is
front ones that is
http://www.ozhonda.com/forum/showthr...ighlight=brake
just found that
is it same/similar for the fronts?
Exactly the same for the front. Unscrew the two screws on the rotor, you may have to tap over the screw driver with a hammer first to unlock them, then unscrew, and take the caliper off. 5 Minute Job really.
