I want to bleed my brake fluid to change it. How much brake fluid will i need? its for a dc2r brake system. thanks.
http://www.ozhonda.com/forum/showthr...ke+fluid+flush
check out the above for the brake fluid flush ~ according to most its abot 500ml for a full flush. Just get 3 containers and save the left-over for a clutch fluid change.
*moved to the integra forum*
But depends on how 'good' you are. I'd say about 2-3 containers of OEM fluid. See here and read the thread fully :)
just found the thread after i posted. should seach first. thanks.
if you have low pressure ABS system
500ml 1 bottle
if you have High pressure ABS
2 500ml bottle
1 for normal brake system
1 for ABS system ( and thats not just changing the fluid in the resivour ) you have to bleed the High Pressure ABS system.
you should try the dot 5.1 from motul... good stuff..
bled my brakes on the week end and can feel the difference. only used a 500ml bottle with a few drops to spare..
my 2 cents any ways:D
i would stick to the dot 4 brake fluid as it is less inclined to attract the moisture the way dot 5 does..is much better suited to road use as it does not require replacing as often
i just got 2 bottles of Castrol super dot 4. Should be enough for full brake and clutch flush.
