well 200,000kms is enough so i wanna rebuild it,mild cam,port and polish,nothin drastic...these engines are new to me so wot to do and wot cost...
thanks.
thanks.
good workk! let me know if i need help;
Are you having any problems with that engine as 200k is really not that much.Quote:
Originally Posted by accordingly flash
Basic rebuild with those mods would be 3-4kUSD, that's new bearings, seals, rings, full cleaning, hone, decking, valve freshening, cams $300USD +), and the PnP (about $600USD +). A full rebuild is $5kUSD + and has new pistons, rotating mass balance, crank regrind if needed, rods machined if needed, new valves if needed, bore/hone, and everything in the basic rebuild and more. The cams start at $300USD and go up. It also depends on how aggressive the PnP is. A basic gasket match is $400-750USD and a full, really aggressive PnP can get up to $1500-2kUSD. Then there is shipping if needed and outside labor and machining. I hope that helps. It will be different as some shops charge different labor rates and have different costs for parts.
